Mugabetown - Whoretownin' At It's Worst.
Its an interesting life for sure. Also, unfortunately, the work is starting to wrap up on this project at least, so there's no guarantee even if you do do the courses i'm afraid, pretty much every industry is like that now though.
But yeah (for the tradies), 10 hour days, work 20 days straight, travel, 6 days off, travel, work 20 days straight, repeat. Stay in camps literally in the middle of nowhere, but at least the rooms are decent, food is buffet, gym on site and the like. But yeah it gets lonely, you do get days off during the week to make up for it but most people are working on those days, which is good for going on drives or getting stuff done but not for keeping in touch with folks really. Honestly don't know how people with kids do it, but the financial rewards must be a good part of it.
That's my issue, everything is wrapping up and there is already a lot of qualified guys out there.
you have to fight for what you want these days Mike
Don't give up because things are wrapping up.
I would see it as an opportunity to find a new and better career or position
There will be more work, eventually, probably plus i'm sure a lot of the folks are on 457's and will probably be kicked out soon once the job ends, so less competition for the next one... You'd really have to want to work out here though to start onto it now.
Depends what you think your prospects are doing what you're already doing (I have NFI what sort of money normal sparkies are on in the city), might not be worth the risk if you're doing alright in here, particularly considering that the gov is pushing to have more houses built as the next construction boom to take over form the mining boom, you might already be in the right spot to take advantage of that (start your own company?)
About $60k a year, not much around tho.
Was always planning on starting my own company.
GTR for those who like parking them in garaghes...or rebuilding 26's
stick with the GTST for track car imo......having said that, a 33 GTR would be gorgeous. the one that Pete linked is f**king swoit
I've built more 25's than 26's
The gas industry is... interesting right now. Construction has peaked on the QGC project for sure, but its not a solid drop off, ok we're done everyone all 15000 of you go home kind of thing. Then you've got the other big players, Origin, Santos and arrow. I'm not 100% sure where they are at, though i've heard that Origin at least still have a fair bit of work to do for the next few years. Then there's always the option of work over in WA or up in Darwin on the LNG plants there. More medium term though i'm not sure about though. As all the work is sub contracted and sub sub contracted out etc there's always a lot of moving and shaking with the individual companies doing the actual work, which can be a good or bad thing depending if you're working for one that gets shafted or looking for a job and one gets hired and told to put on a dozen new people etc.
Your right Pete, all are heading over to the West or to Darwin on the gas works. I go to Mackay every 3 weeks and the coal industry is struggling big time. I know a lot of guys that are being laid off, and having to move away as there is limited work.
In saying that Pipeline work is planned for Moranbah to Gladstone and if Abbott Point finally kicks off it would be good for the region.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
