Mugabetown - Whoretownin' At It's Worst.
I've used this guide for removing the hicas on both my 32's and it works great and is the easiest way to stop the warning light showing on the dash.
http://www.sau.com.au/forums/topic/410492-r32-hicas-removal/
HICAS warning light
Many people have said that locking HICAS causes your steering to get heavy, but they simply haven't done it properly. There has been NO change in steering feel with any of the cars that I have done. The only problem is the fact that the HICAS warning light comes on (because it's not there...). This can be solved by cutting the warning sender wire on the HICAS computer or removing the warning light's bulb from the dash. I prefer to cut the wire as it's quicker, easier and if you for some reason lose power steering fluid, it will tell you when your resevoir is low.
The HICAS computer is underneath the parcel shelf, it is to the right of centre (when looking in from the boot). Unplug the smaller of the two plugs in the back of it and then cut the green with white trace line wire. You can also just leave the smaller of the two harnesses out and it does the same thing, no ill effects and no HICAS light.
HICAS warning light
easy peasie
How is everyone?
I did some landscaping yesterday, my muscles hurt... Thankfully not as badly as I thought they would, I can still function haha! But even my hands are sore! So what do I do? Arrange for 2m3 of crusher dust and pebbles to be delivered today so I can do that along with the other garden edges I need to do :P Never learn!
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
