Mugabetown - Whoretownin' At It's Worst.
Don't suppose anyone knows the part number of the GTR spoiler rubber/gasket kit?
this is all i've been able to find, but getting it from the states seems excessive, will probably pop down to the local nissan parts shop later today.
Edit: Bolt was loose...
was going to say, pretty sure Ants just did a full detail and replacement of his 32GTR spoiler. Cleaned it all up and replaced bolts and gaskets etc. There should be part numbers etc in his build thread. If not just PM him I'm sure being the numbers man he is, he will remember.
Morning Ants.
How goes the Ant Eater?
she goes well mate. I need to replace the nitrogen canister for the 4WD so am on a mission to get that resolved soon.
Sooo much I want to do with the GTR so little disposable income and time
I feel your pain about disposable income. I had to get a second job to feed the addiction
this ^
Check the condition of the stay brackets Pete as they tend to corrode
Good call,
Figured out what i did wrong with part number, didn't add the 05U00, thanks for documenting Antz!
The bolt that was loose was seriously loose, eg finger tight, so will see if that has stopped the leaks for now...
Anyone got a slide hammer I can borrow?
This sounds serious. Is this for the tissuebox?
Pete, if you're gonna rid yourself of that wing, I know someone who'll happily buy it from you, ME! ;) I figured you're not, but it was worth a shot.
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
