Mugabetown - Whoretownin' At It's Worst.
Morning all!!!
Martin's Birthday... But I don't know how likely he is to read this today to know I pointed that out since him and Greg are still venturing home form Skyline Nationals :P Which was awesome by the way...
Back at work, but Yay Friday! It's been a long half a day so far!!!
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
