Mugabetown - Whoretownin' At It's Worst.
Anyone want a fast zed with all the fruit? (no not mine)
Super clean, built engine, 2871's, big cams, nistune, tien coilovers etc etc
Made 430rwhp on 17PSI. Was street tuned, then took to dyno to durn the boost up. Made the 430 on first pull. Turned boost up and blew a recirc valve block off bung apart, which ended the session.
Will make 550hp easy on PB98.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
