Mugabetown - Whoretownin' At It's Worst.
Mangs,
Against my better judgement I have volunteered to do the 50km bike ride for MS Brissie to the Bay on the weekend. If you can spare anything please donate and help me get to my lofty $250 goal by this weekend and get those sweet sweet tax deductions just in time.
https://msqldevents.com.au/champion/MS-Brissie-to-the-Bay-2015/ColinCox?utm_medium=email&utm_campaign=btb15_fundraising_dashboard_05_f_r75_ro75_ru250_tc_tm&utm_content=btb15_fundraising_dashboard_05_f_r75_ro75_ru250_tc_tm+CID_905295c7c42c8be758ebbb108387904b&utm_source=elevate&utm_term=httpsmsqldeventscomauchampionMS-Brissie-to-the-Bay-2015URLfallback
Cheers
Colin
Mangs,
Cheers
Colin
If MS are going to be providing a receipt (exceeding $2.00) on your behalf then it will be a tax deduction to the donator, and unless you are a registered DGR guess............no tax deduction.
Also, not having a dig at you, just good to clarify for all. Happy to donate for you to burn calories
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
