Mugabetown - Whoretownin' At It's Worst.
Meh, just another EOM. Looks like there will be at least another 18 EOM's for me here, which is good. Will be better once confirmed on paper.
Other than that, need to pull zed engine :( Exhaust mani gasket change.
Finding the time is the killer!
How is SS 2.0 going?
Edited by MagicMikeZ32
Have son now with teeny tiny hands and bendy elbows. Should be of much help soon. Just needs more work on his fine motor skills...
Poor kid doesn't stand a chance lol
  • Like 1
ha! may have to wait a few years mate.
Hopefully he will be as much as a Z fan as you are (or anything else JDM)
Cara is going away for a weekend on the 22nd and leaving him with me. I plan on getting the bouncy chair hang-y thing and hanging it from a beam in the shed. Will see how long he lasts in there before getting cranky!
SS2.0 os going well, need to find the time to do the suspension and buy some real tyres.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
