Mugabetown - Whoretownin' At It's Worst.
pray to the car gods for me..
seems both sean and david are booked solid! how the hell can I get the car ready for sep 19!?..
been there mate. This time of the year is insane for the workshops with events like powercruise just around the corner
I will pray for you Dale but I usually find this a waste of time.
haha yea,
well I could always leave the pfc in and run it, and leave the ross trigger kit and haltech out until I get it on the dyno.. but I don't like this 7degrees of timing m ovement..
I just saw over in ur thread ur partin out ur beast? damn shame..
haha yea,
time to move on for me mate.
Will get a boat later than the track
