Mugabetown - Whoretownin' At It's Worst.
Afternoon sir. Does that mean that motor and turbos and everything will be sold in order to start afresh? Few vultures may already be circling around that block.
Yes, most likely.
I was thinking of keeping it but I'm thinking that the next build will most likely be stroker
Yes, most likely.
I wonder who will pick up that motor. 2.8 stroker or 26/30 Ants? Choices choices choices.
I like 2.8 sound of things but everything is trending to 3ltr+ now which I personally makes things more complicated than what it really should be.
But I will once again do my homework first and then take it from there.
The big block boys have been saying it for years "there's no replacement for displacement". The cost of building a 26/30 would be punitive compared to a RB28 I would have thought? Or you could just go a Rb34 ;)
BTW I purchased a bottle of Laprhoaigh last week (the select cask)
That shit is so peaty that you want to punch your grandma in the face!
F me!
That stuff is nice! Although you aren't a peat fan from memory. It's ok, I don't think he takes it personally. :P
Yes, can't beat cubes hence Nick lol
Yes, I actually wouldnt mind getting another bottle which is called the quarter cask - 48% abv and has some really good reviews but yeah Peat and I don't get along as well as Sherry does.
Quarter cask is one of my brothers favourite drops. I too quite enjoy it. For your palate, I do recommend the Dalmore range or the Aberlour. Good stuff! Had Dalmore 12 earlier tonight and enjoyed it.
the QTR cask has scored 96 points. But yeah for me I like sweeter whiskys. Doesn't mean I don't like peated malts though
The Dalmore 12 is insanely sweet.
The Macs and Dronachs are one of my favs
But I like all kinds of whiskies
Yes, it's about tastes and also the mood you're in. Having said that I'm always keen to explore and expand my knowledge by trying other whiskies.
The Dalmore cigar malt is nice and the 18 I must try one one day.
Arberlour is on my to do list.
Right now though on the hunt for some Japanese malts :)
Japanese hey? Very pure crisp flavours. Which in particular?
any mate.
I've recently purchased Nikka from the barrel and that is just unreal
The best nose of a blend I've ever had and tastes magnificent.
Last night I had (a whee bit too much) Laphroaigh Select cask but that's because I really enjoyed that smokey aftertaste
Think I'm going to buy that QTR cask now, as I think I'm hooked on it now lol
The more refinement that goes into these peaty and smokey whiskies the less it tastes like an ashtray. The Ardbeg Perpetuum for example, nice heavy notes of tar and soot on the nose yet dark chocolate and honey on the palate. When you take a sip, has a nice warmth to it followed by smoke.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
