Hey :)
I am doing a complete overhaul...
Upgrading and refreshing everything. So at the moment it's garaged and out of action :(
Which sucks, but it will be worth it :D eventually!
ii
Hey, how's the Skyline going?
Hey :)
Ohh big effort, I'm just in the middle of the same thing.
What are you doing engine wise??
Hey :)
Are you running twin or single turbo and are you still running AWD?
It's a single turbo and it's rear wheel....I've got a R33 GTSt...my name has GTR in it because GTSt_girl was taken haha.
I'm pulling the head off, getting it machined and match ported
all new valves
hks drop in cams
HKS cam gears and timing belt with a clear cover
tidy up the injector and coil harness
relocate the igniter
new water pump
upgrade from a mechanical to a thermo fan
heavy duty clutch kit
coil overs cause mine are destroyed
full nolathane kit for rear diff cradle, steering rack, sway bars etc.
bendix ultimate brake pads
overhaul on calipers
And basically a once over to suss whatever else needs maintenance as it's a 93 and I have given it a whooping
Just some of the goodies
When I manage to find one/afford one I want to put a GTR spoiler on.
GTR badge for the boot
full respray
replace the carpet
retrim
that's about it...just trying to keep it as standard looking as possible.
I only use GTR and nismo parts, no knock offs or fibreglass crap...so things are expensive thought worth it haha.
what are you doing to yours?
full respray
replace the carpet
retrim
That sounds really good!!! Your 33s pretty good! Like it's not something I'd expect a girl to have the keys to haha but that's awesome, girls who build cars.
Well you're in luck! I have a GTR spoiler here, it needs paint but that's normal.
Um well last time we spoke it was stock as a rock but so far I've done:
Return flow catch can
Alloy radiator
Greddy inlet manifold with 80mm TB
Godspeed hybrid FMIC
Turbo smart plumb back BOV
Cps full exhaust 3.5" with 5" decat and cannon
Bigger injectors with side feed rail
Spit fire coils
New plugs
Upgraded MAF and pod
GTR grille
Drift tecs
White carbon cluster with blue and red lights
New dash
New seats
Walbro 410LPH pump
Fuel regilator
Power fc
And more
Haha thanks, I get that a fair bit. Love my cars :D
How much would you sell it for!? Been after one for forever haha
Yours is starting to come together quickly. Happy with it so far?
Alloy radiator
Spit fire coils
New plugs
GTR grille
Drift tecs
New dash
New seats
Walbro 410LPH pump
Fuel regilator
Power fc
And more
Hey Brodie!
Yeah i think I've met like 3 girls in my whole life who don't roll their eyes when cars are mentioned haha
Yeah I'm so happy with it, can't put the tools down, or my bank card for that matter
SORRY LAND son of rajab ;)
But yeah they're fun cars to play with!!!
Mmm I'd sell it for $500 x 2 / 4 -100 x 3 - 300
;) have fun with that
Welcome to the SAU world Brodie! Female + Skyline = :wub:
Your car looks Awesome with those Rims and a GTR Wing will Definately be Tougher than the series 1 wing but please, for love of the God of Boost, don't put a GTR badge on a Non GTR. :/
Having said that, Enjoy your car and all that SAU can offer. :thumbsup:
all new valves
hks drop in cams
new water pump
just some tips....why all the headwork....you want a better flowing head just put a neo head on it...either way its a waste of time really...dont bother unless its stuffed and needs rebuilding...bendix pads are junk and will dust up those beautiful wheels like crazy...putting a thermo fan is not an upgrade...its actually a downgrade...
full respray
replace the carpet
retrim
ok you lost me now...:glare:
do not put a gtr badge on.
or do. i dont care its your car.
welcome.
inb4 all the forum sex pests show up.
nick? :whistling:
but you're already here.....
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
