Brisbane Boys College and The Univeristy of Queensland :P
The high school is right but sadly you went public on the uni and worked part time while doing it, such a shame, should have gone to bond at the very least, but probably should have got someone to send you to Oxford or something.
Do you still have your cool straw hat?
Like Tony said the school part is fine (despite the green and the straw hat) its the very undistinguished life you lead now that would have the Libs scratching their heads, 'part time work? Why doesn't he just get his grand parents to send him to oxford?'
I should be careful here, I will end up as a liberal candidate, also went to a Gps school and never worked a minute during uni! Haha
Which Uni though?
Just saw that it was Griffith. Not good enough there Bunta :P
Which Uni though?
Yeah I dont get all the points. I went to Griffith, and while I did it on family funds (no hecs, no part time work, no centrelink) I didn't go to somewhere where the plebs are not allowed lol
With all that factored in you could run for a small rural seat somewhere insignificant I guess? :P
I would just go with the Nationals, I would get in in Nicks seat and I would go about making laws to ban bogan engine rice mobiles
Do it! Do it! Do it!
I will try and con someone into embezzling SAU QLD funds to promote this :P
  • 3 weeks later...
Tony and I actually had a chat about this WAY back when they were first starting to organise (before the AMEP were formed) and we basically came to the conclusion that you had damn well better make sure that everything was 100% stowed away and ready before you start making waves and taking the fight back to the big boys or else the blowback will destroy you.
A wise person once said you don't pick fights with people who buy ink by the barrel, looks like that's still true today. Death by media and motoring enthusiasts cop a massive body blow as a result.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
