Guys,
My missus has a silver nova and for christmas a couple of years ago she got some turtlewax colour cure car polish. Anyway I decided to give it a try on her car to see if it was any good before trying some on mine :P Her front bonnet was replaced a few years ago when she had a prang but it wasnt sprayed properly and has faded over the years, so I gave it a coat of this polish stuff (its a liquid thats the same colour as your finish, ie: black, red, silver etc) and after the first coat had dried I buffed it off, it wasnt perfect but you could see the difference. So I gave it another coat and buffed it back and it was getting better. So I went and picked some of it up for my black r33 today and I've just finished applying one coat and I must say thats the best non-professional polish I have seen. It could do with another coat, but it got dark too quickly and I dont have a garage otherwise I'd be out there giving it a 2nd going over. It also comes with a chip stick for doing stone chips, it didnt work too well, but you are meant to use the chipstick when the cars in direct sunlight and hot to touch, I guess so that the stick can go a bit soft and get into the deep scratches better, I'll give that a go next weekend if its sunny. But I have to say give this stuff a go, I've only seen it in black, red, silver and blue and its only around $19/bottle. My front mount cooler should be here next week, so hopefully by the end of the following week its in and I'll have some pics to post! :uh-huh:
Rob
https://www.sau.com.au/forums/topic/4316-polishing-stuff/
Hi Guys and Girls - my first post finally
I have been using the Turtle Wax Colour polish for a number of years when they first released it as something else - it is also really good at removing marks and small scratches although haven't tried the chip stick.
I haven't actually got my Skyline yet but am waiting for it to arrive from Japan in about 2 weeks time and then to get it complied. Will be a big step up from the Celica that's for sure.
This will be my first turbo car although not my first import as I used to have a Mazda 626 coupe and a Mirage in the early nineties before compliance was required.
Being new to all this I suspect there will be quite a few questions, etc from me.
Cheers, Al
https://www.sau.com.au/forums/topic/4316-polishing-stuff/#findComment-68505
Originally posted by skyzerr33
yeah but what polish or color do u use for a burgandy skyline with a faint gold pearl through it?
Thats a tough one although all I could suggest is trying it somewhere hidden and see what it does, the polish is supposed to use the car's own colours but the gold could be difficult
Al
https://www.sau.com.au/forums/topic/4316-polishing-stuff/#findComment-68529
Yeah I use that Turtlewax stuff and it is pretty good, but not as good as the bottle or TV ads say it is. I found that adding a some to a medium abrasive rubbing compound when removing any marks, light scratching or paint faiding on the car works an absolute treat, I had to polish my entire sisters eunos 30x like this when it's paint had faided terribly, it took me a day but in the end it looked better than new, like a show car.
Greg. :devfu:
Ps the chip stick is the biggest load of crap I have ever seen, I advice no one uses it on their car.
https://www.sau.com.au/forums/topic/4316-polishing-stuff/#findComment-68816
Originally posted by Kyles
i found it quite funny you tryed it out on your wifes car first!
That way he can say: look honey i made ure car look all nice and shiny arnt i a good boy:D (extra brownie points)
And if it didnt work he can say: Who made this dam polish, i wanted to make it all nice for u and look what happend blah blah (while hes really thinkin "dam, glad i didnt try it on mine:D")
https://www.sau.com.au/forums/topic/4316-polishing-stuff/#findComment-68823
ive actually heard that this stuff isn't good for your paintwork!
there was a thread about polishes etc and some people had proof that over time it deteriorated the paintwork... i used to use it but being paranoid about my car have now stopped.
i use meguliars gold class wax, it takes a while to do 1 coat (which means it only happens once every 2 months!) but the finish on that is excellent. pity it doesnt last too long on the black car!
https://www.sau.com.au/forums/topic/4316-polishing-stuff/#findComment-68886
    • My car is also flex tuned. It's worth mentioning it (the LS1 ECU) has a 1D table for E85 addition and just uses the ethanol stoich part as the second point of reference. It also as a 3D timing map for Ethanol adjustment. You would think this isn't enough but it works pretty damn well. That said, I wouldn't want it in turbo application. It's like lifting non-natty, or taking meth. It gets you unrealistic results that break down more things going forward. If people used it to make the same amount of power they do on 98 then it'd be one thing. But people use it, crank it up to eleventy million PSI, it doesn't knock - but it pushes the point of failure to another, more expensive thing to break. Every time I see someone make 280kw on 98 and 350kw on E85 on the same equipment I just cry a bit and really wish they would just stay on 98 in that exact scenario. It's bad for you.
    • This is kind of what I was thinking but the temp sender wire and the two pressure switch wires run through the starter subharnes and I eliminated the two pressure switch wires completely.  @GTSBoy I have a can gauge with unusually bright warnings should the oil pressure fall so the factory light isn't needed. I need to dig out my wiring diagram and see if I can sort this out.
    • It's a valid point. And it is doable with the Nistune. But I'm not inclined to flex it the way Nistune does - certainly not on a Neo ECU. They're already pernickety enough to tune just one one fuel. And of course, I'm not that interested in putting in a Link or similar, on a daily. With the stock ECU, stock looking turbo, etc etc, I still stand a chance of surviving a run-in with the plod. Last time it went over the pits (which was for the transplant, for because of a run-in with the plod), the Nistuned ECU did not even raise an eyebrow. They want to see a stock ECU running the engine, and they are happy to see it do so without the check engine light** on. Never mind that the Nistune is necessary to make the stock ECU work in a different chassis without ABS, TCS, etc. **And they actually provoke the CEL to come on by disconnecting the AFM, to prove that the globe hasn't been pulled!
    • This is why you flex fuel it...
    • That is what I took from it too. Needed to go AWD S14 imo.
