Hey guys just out of interest as I'm used to nz pricing on highly modified skylines.
But out of interest what would a 34 gtt with low genuine k's on it say maybe 30,000kms.
And still running 25det pulling between 450 / 500kw at the treads be worth ?
Edited by Cyifly
https://www.sau.com.au/forums/topic/431795-how-much-for-high-power-low-k-gtt/
Ok I'm gonna bite
Genuine 30km R34 GTT probably doesn't exist and if it did in Aus, you'd be looking at ~ 20-25k min.
450/500 rwkw R34 GTT - would guess 30-35k fully built etc?
Thanks for giving us an idea i had really have no clue for the market over here. But as for the existing part...
Lets just say mine is genuine complied kms. I bought it with 13,000kms on the clock. And yes fully built. While build roughly done 17,000kms
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
