Hi USRB25S13 , "Over boost protection" is what it is know as, but it is really "excessive airflow protection". The ecu makes this decision based on what the AFM is telling it. So boost really has nothing to do with it. The fix is an SAFC, voltage clamp, Boost Cut Defeater or better still replace the std ecu with a Power FC. Full fuel cut is the next step in engine protection programming in the ECU, but you get "retard" and "rich" first.
Here is a post I prepared earlier that may help
Hi guys, a quick, simplistic explanation of how an SAFC works might help...
As the airflow into the engine increase, the AFM records this as increased voltage that the ECU sees. What an SAFC does is sit in between the AFM and the ECU and take the voltages from the AFM and either increase or decrease them depending on what you have programmed the SAFC to do. By increasing the voltage, this tricks the ecu into pumping in more fuel, you do this when the engine is running lean. By decreasing the voltage, this tricks the ecu into pumping in less fuel, you do this when the engine is running rich.
The next bit is hard to understand unless you remember that the standard ecu does not supply fuel in direct proportion to the afm voltage ie; 4 volts is not twice as much fuel as 2 volts. Engine rpm, boost and throttle position also help the ecu determine how much fuel to add.
It has been my experience that RB25's run a little lean down low in the rpm range (Nissan do this for fuel economy and emissions) and a lot rich up high (Nissan do this to protect the engine). So I have to increase the voltage (using the SAFC) up to around 3,000 rpm and decrease the voltage over 5,000 rpm.
The real problem is in the 3,000 to 5,000 rpm range as the engine comes on boost. They really need lots of fuel very quickly in this area. This can mean that you need to increase the voltage (that the ecu sees) over 5.1 volts to get the right A/F ratios. The ecu then goes into engine protection mode, rich and retarded (sounds like a girl I knew once). Past that rpm you can start leaning it out as it runs too rich, so the voltage needs to be turned down under 5.1 volts. The ecu sees this as the engine not needing protection mode any more, no more rich and retarded.
So you get good performance up to 3,000 rpm, then sluggish from 3,000 rpm to 5,000 rpm and then good performance from 5,000 rpm and over. The SAFC may not help this, in fact as explained above, it can in fact make it worse if the tuner is not switched on to this stuff.
With bent afm voltages, the ecu (tricked by the SAFC) also fires the ignition to suite the airflow it THINKS the engine is getting. This is not a good thing as you generally end up with ignition that is too far advanced in some rpm ranges.
The poor tuner has to juggle the SAFC settings, so that the A/F ratios are OK, the ecu doesn't get into rich and retard (engine protection) mode and the ignition timing is not too far advanced so as to cause detonation. My experience (I am not a good tuner) has been that this is full of compromises, sometimes you just can't win and have to reduce the boost level a bit to get even a reasonable compromise.
Keep in mind that this explanation is very simplified to make it fit in a reasonable space, the rpm's used are rough guides only and every car is different.
Hope it helps (and makes some sense).
https://www.sau.com.au/forums/topic/43180-fuel-cut-defender/#findComment-882968
the ecu will retard too much at 17psi. there will be too much airflow and the timing will get retarded heaps. i would seriously look at an getting an aftermarket ecu before even considering 17psi. youll get much more bang per $ if you had an aftermarket ecu and 15psi vs stock ecu and 17psi
https://www.sau.com.au/forums/topic/43180-fuel-cut-defender/#findComment-883633
What kinda Timing adjustments can you make with the PFC? The main problem I have here in the US is finding one. I either have to take my chance on ebay or find a good source some where (wink wink) to sell me one. I may just get a standalone (Haltech or Tech III) for they may be cheaper/easier to get.
https://www.sau.com.au/forums/topic/43180-fuel-cut-defender/#findComment-884585
Looks like a Power FC should be on the top of my future mods list.....Can you still have a boost cut with the power FC? Just for overboost protection.
Firstly you tune it properly for your boost level. You can of course tune it for more boost than you run via the boost table. In other words tune it "normally" with optimium A/F ratios and ignition timing. Or you can add extra fuel and/or retard the timing if the boost goes above your target. You can make this a "saftey net" (only a bit richer and a bit retarded) or "protection" (dump heaps of fuel and lots of retard). "Protection" is like the standard ECU. The standard ECU then has full on fuel cut off, Power FC doesn't have that for obvious reasons.
Whatever you want, there is no limit to the ignition mapping as long as you stay within 20 X 20 load points. Plus you have correction tables for temperature and boost.
Try www.nengun.com they sell to anyone, anywhere at good prices. I have bought plenty of stuff from them, not one problem.
Hope that helps
https://www.sau.com.au/forums/topic/43180-fuel-cut-defender/#findComment-884641
QUOTE ()
What abot putting s chip in, could that do it?
There are limits as to what you can do with the standard ECU, but yep it would work. But you have an R33, they are extremely tricky (ie; expensive) to chip.
https://www.sau.com.au/forums/topic/43180-fuel-cut-defender/#findComment-889781
QUOTE ()
how much do u reckon im lookin at? after this im done no more money to the engine, unless it has to be done, and things always need to be done :)
Pretty much cheaper to buy and tune a Power FC and get it over and done with.
https://www.sau.com.au/forums/topic/43180-fuel-cut-defender/#findComment-890257
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
