A speed cut defender basically works as a bypass until you get to a preset speed. For example, at 100km/h it still says you're doing 100, but if you set the max speed to say 175km/h, at 180 it still thinks you're doing 175. And at 250, it still thinks you're going 175... so the ECU won't cut power. I've always been a little skeptical about them though, I'd much prefer a full aftermarket remap of the ECU which incorporates the speed cut removal. I'd feel much more comfortable doing it that way.
Colin
Your car sounds like a bit of a weapon mate... good work :cool:
Can you give me any more info on the alarm?? PM me if you like. I *might* be upgrading to a GTR shortly and would be very interested in putting something like that into it.
Tze
That's the same reason I've left mine alone. Not sure if it has mixture compensation for speed/gear or whatever, and who knows what else. One way to do it would be to put a switch on it - leave it stock until you want to blow past someone (on a private road of course :D )
https://www.sau.com.au/forums/topic/432-qld-members/page/9/#findComment-50065
  • Replies 250
i'm not too sure how the speed cut defender works, but for bout 200 bucks i dun mind trying it out. if it's like wat u said then my turbo timer's speedo wun work rite?(it's wired into the ecu) anyways still waiting for u guys to get a cruise going, or a meet up, or whatever. can't wait to meet up with u guys again. btw i got whopped by a red nsx...i was in 5th doing 60 n this red thing just flies past doing sumthing like 130 i think...by the time i dumped the gear into 3rd he was thru the roundabout(indooroopilly) and gone man...his exhaust was the loudest thing i heard...(in vtec man)....now i want a honda...:burnout:
https://www.sau.com.au/forums/topic/432-qld-members/page/9/#findComment-50755
Guest nismogtsx
These alarm systmes are aviable at any good car radio
joint. I got mine at Complete Car sound at Enoggera.
Its on pickering street. They do great deals and stock
heaps of good gear. They are full of great advise
and know how to work on a budget. Its just i got hooked
and went a little over board with my stereo. (ie. front
splits $1200 - and thats with a discount)
Mines a VDO system and it costs around the $1200 mark.
These days im sure their a bit cheaper. Anyway if the alarm
goes off you mobile will ring (I set the number to car alarm).
So when it rings the display on my trusty Nokia says
"CAR ALARM". From there you can hit the clear button and
this will reset the alarm. Just incase it was a crack of thunder
or a loud exhaust. But if it goes off again then dial the number
back and then type in your pin number and the car stops dead.
Simple system which works well.......
Only costs you the cost of the mobile phone call, but it can
save your car. I should also mention that the auto wind-up
kit and central door locking is an extra expense. But they
both simply connect to the VDO kit. I installed it myself and took
2 days to fit properly. I also fitted a auto start to it, so i can warm
the turbo up before i even get to the car.......
I call my car "Kit" as in kit from knight rider cause it has just as
many electronic gismo's at the real thing.........
NOTE: The model i am using is now out of date and there are
better kits aviable now. Also never mention the Model number
to anyone, cause the pin number for the system is the model
number plus one digit and therefore it can be very dangerous
when in the wrong hands.
ALSO NOTE: A thief can never tell what model it is as every wire
is a black wire and the model skiter is removable before installation.
Cheers Colin
Yes the car is a weapon........ Not only in the rain..........LOL
https://www.sau.com.au/forums/topic/432-qld-members/page/9/#findComment-50757
Guest nismogtsx
Im local, i used to live like just round the corner.....
But i live near Aspley now.......
Complete Car sound is the only place i have been
where they dont just try and sell you "Sony or Pioneer"
(ie. Auto Barn) they have a wide range and im mates
with the guys down there. I also hold a gold membership
at this joint so i get really good discounts.
https://www.sau.com.au/forums/topic/432-qld-members/page/9/#findComment-50763
Not sure what you mean about your TT's speedo not working... I assume you mean that your TT acts as a digital speedo as well? If that's the case, you just have to make sure you wire it in BEFORE the speed cut defender, ie closer to the speedo sender, not the ECU.
What the hell were you doing going for 3rd gear at 60, you should be using second at that speed!! :D
https://www.sau.com.au/forums/topic/432-qld-members/page/9/#findComment-50959
Originally posted by Chucky
Car: R33 Skyline - Lots of mods & Silvia S13 - 4 Sale
Occupation: Manager
Can't wait to meet all of you guys and go crusing.
Well, you just missed out on last weekends 'eventful' cruise. Around Hinze damn and down to Murwulumbah..
https://www.sau.com.au/forums/topic/432-qld-members/page/9/#findComment-51679
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
