I understand that they have inbuilt ignitors in the coilpacks, and have the signal from the CAS to fire, BUT if you were to use the s1 loom using the EXTERNAL IGNITOR with the s1 coils, will I be able to do this? I can sell the coilpacks, but I'm I want to see if it can be done, the coils are less than 2000km old, it's cheaper If I can go this way and to be honest in my opinion integrated ignitors on coilpacks is a more un reliable set up as it's introducing further heat to a area which is prone to cracking ect ect, it's not so much about $$ but more so using what I have and reliability
Cheers
the connection wont fit. but if you get the ignitor loom, and coil loom you can cut and wire it in manually. a good tuner electrician should be able to do this without any issues.
but you are better off trying to find someone who would be keen to swap the s1 coils for a s2 set.
by the time you wire it all up its going to be better to just sell the coil packs and buy a proper series 2 set.
Cheers guys, I'm not to bad with electrical, I just wasn't sure if the ecu wouldn't read it or if it was throwing out different voltages ect ect, so in saying that I should be able to do it,
Thanks alot, appreciate the help
The ECU sends the same signals out regardless of which coils/igniters are at the other end of the loom. It's just that the wires run direct from the ECU to the coils in the S2 case and have to stop off at the igniter in the S1 case. In the same way, the various igniters don't much care which ECU is telling them to fire, and they also don't much care which coil they're then firing (assuming separate coil and igniter), unless the coil also has an igniter, which is not so good.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
