R32 GTR Rear Spoiler / Wing
Has been in storage for over 5 years, does have some chips in the paint (came to me this way) but NO damage to the Fiberglass.
The rubbers, nuts & bolts are all there & included!
I'm not sure of the exact colour, if you know feel free to add confirm?
It's either
#AH3 - Red Pearl Metallic
#AN0 - Wine Red
$150
Pick up only from Wyndham Vale VIC 3024
Thanks Brett
[email protected]
Edited by Sydneyactionman
https://www.sau.com.au/forums/topic/432553-r32-gtr-rear-spoiler-wing/
  • 3 weeks later...
$120
Have confirmed Colour = #AH3 - Red Pearl Metallic.
The graphics/writing that says "SKYLINE" I'm pretty sure is reflective tape that can be easily removed if it's not your cup of tea!
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
Hi you need to get your own quotes use 3024
What's shipping rate to Darwin?! I'm as interested as a kid in a candy shop!
Cost including transport is $250
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
