ITEM: Nissan Skyline R33 GTR Series 3 front bumper bar freshly reconditioned ready for paint. Comes with vents and blinkers but not the nostril ducts.
CONDITION: Reconditioned - like new and ready to be painted
PRICE: $1,400
CONTACT: PM or call O4O4.193.556
PICS: will upload over the weekend
Will separate:
front bar $700
lip spoiler $800
  • 1 month later...
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
