i've got 33K saved already... yeah ive seen eriks r34 very nice but i really wanted a white or yellow one though. i dont mine waiting 3 or 4 months as ill be buying at the end of the year anyway so i can save a bit more dough.
ive only seen manual r34 for 40K+ and auto for 35K so eriks is quite a bargin.
Does anyone know any dealers etc...
extreme machines is a good place to test drive a r34 but to buy is absolute rip off...
import is the best way but waiting is a bitch i went through prestige motorsport to get my car and am waiting on the arrival of it but geoff frfom prestige has been most help full with every stupid question i ask plus he is perth based...
it is a much cheaper allternative to import and he can help you find any colour and mods you want for your budget......
R34's are avialable in the eastern states and will be avialable any day now here for dealers and personal importers as a couple are sorting out vehicle inspection, I know of one who will help you buy a car free of charge if you buy a plate off him and yes the price is the same as everybody else.
Dont bad mouth peoples prices either if you dont like it keep it to your self and dont post it.
www.j-spec.com.au is also one of the guys who started it off and he buys grade 4 cars that can be inspected as you dont want a damaged car as a couple have to be exported already.
Talk to local RAWS who have R34 compliance as the DOTR's site is updated daily or do research as the first post web site is just cut and paste of cars in stock that have already been bought so imagine what the real price is.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
