Harro,
Just stuff lying around the garage, all parts are used.
Factory Steering Rack Ends/Tie Rods $10
Factory Steering Tie Rod Ends $10
Factory SMIC $50
Factory SMIC piping $50
Factory Cross over pipe & BOV $50
Factory Down pipe $20
Factory Dump pipe $20
Factory Catalytic Converter $50
Factory O2 sensor $10
Factory Mint Handbrake OEM boot $10
Factory HICAS unit $20
Factory Passenger side kick panel, 1x flare clip broken $5
Factory Stock R33 Rims x4 (tyres might not pass an inspection) $100
Bendix DB1170 Front Brake Pads (Near New) - "Guaranteed Race Car Like Squeal" $30
Blitz 60mm Gauge Holder $5
Subframe Lock Collars - Blue in Colour, full set (8 pieces) $40
Contacts: PM or Reply Here
Location: Canley Vale, NSW, 2166 (AH) OR Milsons Point, NSW, 2061 (BH)
Will post some items, but prefer pick-up. Will give discount on bulk purchases, and yes I accept beer as payment also (no VB, Fosters, XXXX, etc..)
Would you post to sa? If so how much would you want for them sent?
yeah and $20 ontop would cover it
Schizzle for sale... help me fund mah modz :)
Factory SMIC $50
Factory R33 GTS-t Manual Radiator, working removed for upgrade $40
yezzzzz
Sold:
Available:
Factory SMIC $50
Sold:
Available:
Factory SMIC $50
Sold:
Available:
Factory SMIC $50
Friday bump this schizzle...
You know I'm negotiable right? How about give me 3x slabs of Blonde and you can take everything remaining in this thread.
Sold:
Available:
Factory SMIC $50
Some updates, tyres fell through.
Take everything available here for $150 or 3x slabs of Blonde.
Sold:
Available:
Factory SMIC $50
Factory HICAS unit $10
Factory Stock R33 Rims x4 (tyres might not pass an inspection) $80
Bendix DB1170 Front Brake Pads (Near New) - "Guaranteed Race Car Like Squeal" $20
Fully Sick Gearboot & Handbrake Boot in black leather with purple Stitching $10
Sold:
Binned:
Available:
Factory SMIC $50
Hey bud
I'm interested in the dump pipe, down pipe and the bov (if you're willing to seperate it)
Though i'd need it posted to vic.
I'll pm anyways
  • 3 weeks later...
Sold:
Binned:
Available:
Factory SMIC $50
  • 1 month later...
Available:
Factory SMIC $50
Superlow Rear Springs R32/R33/R34 GTS-t/GT-t $40
Sold:
Binned:
Available:
Factory SMIC $50
Factory Blow Off Valve $30
Factory R33 GTS-t Manual Radiator, working removed for upgrade $20
Sold:
Factory Cross over pipe $30
Binned:
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
