  • Replies 46
It was a decent leak, no wonder it was blowing fuel out the zorst the last 4 months.
A quick pressure test would have found it in no time. :P
I finally got access to a workshop and compressor - but we couldn't find any leaks under pressure, we replaced some pipes and worm drives for good measure though - it's all nice and tight now but the problem persists.
He did do a pressure test! makes me worried about my black smoke now lol
Dunc has the black smoke completely gone?
Edited by Dane
We did try a ghetto pressure test but Id say the bung wasnt good enough. Definitely needs to be specifically crafted for the hose you're fitting it to :P
Awesome result Dunc!
:thanks: Very stoked.
Probably not 100%, I'll need to throw a gopro on the back again to confirm - but I'd say there might be a couple of rich spots in my map (Untuned, highflowed turbo) but its not like it was in the youtube clip any more; any black smoke would just be if you were looking for it. I can rev it out to 7k at 17+ PSI and theres no dead spots after gear changes.
If you haven't pulled the hose off on the passenger side after the FMIC, do that.
Try the hose between the intercooler & turbo...
I can see you posting, but all I'm reading from you is "I sold my Stagea and now I'm a lesser man"
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
    • Was that also a typo? $350?! Just typing "BMW oil level sensor" and prices start out a lot more sanely than $350. I'm guessing it's a sensor used in one low volume model only or something?
    • They kept the product number the same, so we "didn't pick it up when packing your order". If you packed the order, you clearly saw the box wasn't Hella...
    • Actually, the equivalent skyline part is both cheaper and simpler, maybe you should come back from the dark side?
