Hey guys n girls looking into buying a 180 for a bit of fun at the drift practices , not really for me but for the wife and id love to know what if there are any rules and regs that we would need to adhear to to go out and have a blast
So far ive read that headlights,taillights,long sleve, long pants and an australian std helmet are the minimum but what about half/full cages bolt in ? Weld in ? Basically anything i would need to know before rocking up on the next saturday night to only be turned away....
Cheers in advance !!
https://www.sau.com.au/forums/topic/433279-drift-at-lala/
What you have been told is correct aslong as all lights work u have a seat belt and long pants n shirt is all u need. although i recommend a half cage for a bit of safety it not a necessity.
But what u MUST DO IS HAVE FUN !!!
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7062129
Cool stuff guys
The wifes hell bent on having a drift car so we have been looking around at anything that already has a cage or half bare min just to up the safety level a touch more
On that note please flick me a p.m if anyone has something ready for a slide around the 5k mark, dont want to spend heaps as i really dont know if she will like it enough to buy something decent so just a hack for now.
Hope to be out at next prac to make arses of our selves :)
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7062304
Hey that would be great, just put a deposit on a 180sx that is set up for drifting so we will see how it goes, going to chuck it on my dyno first and see if it is tuned like the bloke said and maybe have a fiddle with the power fc ( only tune ford xr6t's )so hopefully i dont blow it up lol
Cant wait to get it out as the wife is hanging to learn how to slide and iam apparently the teacher ( only ever power skidded 400kw barges ) so its going to be a dumb and dumber type of thing i can see
More details on tailem bend would be great as i know sfa
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7063759
Ok fellas i know its not a skyline but its more drift related and this is where i think the skyline community will dominate
This 180 has a drift button handbrake set up, what are the gains by going hydro handbrake if any ? Only starting out but if its "easier" ill do it because the wife will need everything on her side to tackle this art form
Any info will be great
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7068303
Hydros are just a bit more dependable because you know its always gonna lock up 100% of the time. A standard handbrake that's nice and tight with some decent shoes will work just as well
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7068423
Arhh i see just a bit more of a consistency thing !
The car has a half cage and a pile of other bitz but i have nfi if there good or not, this is the list from the add, shout out if something needs to be changed or added please
Nissan 180sx drift car
Rebuilt s14 sr20det less then 1000km on it
Tein coil overs all round
S14 manual gear box
Camber tops
Surge tank set up
Sparco 4 point harnesses
Racaro bucket seat
Koyorad alloy Radiator with thermo
Fmic
Holford motors cams spec bolt in half cage with harness bar
Adjustable arms all round
Catch can
T3t4 turbo with braided lines
Spiltfire coil packs
Fuel pressure reg
Boost tee
Carbon fiber vented hood
Locked diff
770 cc injectors
Aircraft alloy winged and gated sump
New flywheel
New extreme drift clutch
Oil cooler and filter relocation kit
Metal head gasket
Rocker arm stoppers
5stud conversion all round
Brake upgrade
Wide body front and rear
Rear strut brace
Engine damper
Battery relocated
Semi solid k frame bushes
Apexi power FC with hand controller
Drift BOV
Rotas warped in federal 595 up front
Also comes with spare rack ends wheel studs and silicon rad hoses Also with 8 spare rims 4 of which have 100% brand new tread.
The interior has been stripped and sound deadening has been removed. Paint is a little rough but can include 8L of plasti dip if I get right price...
This car was dynoed at Fisher performance 3 months ago at 242.5 rwkw. I
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7069006
All you need to start with is decent diff (even a welded one with be ok), a working handbrake and a decent seat to hold you in. It looks like that car has all the essentials and more.
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7069122
Before I went out for the first time I went to watch it and see what the go was. When I got to actually go out I would just head for the middle of the corner with a bit of speed and then pull the hand brake on then turn into the corner. The car would start to slide the rear out. While I was putting the hand brake on I would have the clutch in getting the gear ready. Give it some revs and then remove hand brake and drop the clutch while turning opposite lock. I also hit the wall in last session but I had fun. Would love to do it again one day.
You sound like you have got a good start with the car.
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7069447
Drift school is worth every cent, the boys out on the track are super supportive and the vibe is awesome friendly.
Get out there in whatever you got, don't stress about being over setup and you'll soon quickly workout what you need in terms of hydro, parts etc :)
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7069751
Well we did not make it out, chucked the 180 on the dyno late friday night to find issues, bloody head gasket had gone and we have custard filling
The bloke we bought it off sent the new built engine to fisher performance to have his other better head fitted and a metal head gasket fitted and then tuned
Well something happened warped or cracked or just not torqued up correctly, trying to get it sussed out now hopefully fisher come to the party but doubtful
Anywhoo driving out to see the drift prac had a bingle in the F6 :( bad weekend but finally got out there to have a look and lots of fun to be had
Just over a month to get ready for this track day at tailem bend now
https://www.sau.com.au/forums/topic/433279-drift-at-lala/#findComment-7081538
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
