Antilag Racewars 2014 - 12Th & 13Th April, Wyalkatchem Airport
Antilag RaceWars 2014 dates have been released today, it will be held on the 12th and 13th of April once again at Wyalkatchem Airport.
Last year was ridiculously fun and I can't wait to wind some boost up, drop some kilos and better last years efforts.
Anyone else planning on going?
http://www.racewars.com.au/
More power is definitely required, seems I've got some quick cars chasing my title.
650 - 700 Sarah Jessica Parkers should do the trick I think ;)
will be entering
shooting for 650 - 700 whp for the event
hoping the 6 speed gives me a bit more pull in the top end
just booked my accommodation tonight, get on it lads isnt much close by around.
True that, I'm staying at the Dowerin Hotel ~20mins out of Wylie.
haha thats where i booked, ZZM5 has also booked at dowerin Hotel.
however am hunting down a house within close proximity of the track, so if we get house will just onsell the dowerin hotel rooms.
Hi, folks.
I enjoyed myself this year and have a point to prove next year! I have booked my accommodation in Dowerin just now. I hope it is not quite as hot and they iron out the kinks in the schedule. The organisers did a great effort for the first year.
Still learning to drive, it would appear!!!
:blink:
whats the point you wish to prove?
More to myself, than anything else. For lots of reasons, I stuffed up and ran in low boost all through the Saturday. Then on the Sunday I only managed two runs on the 1000 metres, because I was flying out that night and had to get back. The first one, the timing didn't work and I had a good indicated top speed. The second one, I stuffed the start and one gear change and the timing worked. So, I came away with the overall feeling that I had not driven the car to its potential. I want to do that this time.
So that is the point I want to prove to myself.
LOL I no own a 31 , 34 is just about finished :)
Weak :P
I only had the one run at 1,000m myself, I certainly had an average start and a short shift, could have gone faster but doubt I could have pulled up in time, haha!
Edited by Hank Scorpio
1000m = need good brakes.
Got to around 230-240 and felt "pretty" safe with hard braking.
Yeah, I think I'll need my 6-pots for if I ever get to 260-270 :P
  • 2 months later...
Entry is in! Looking forward to it - and hopefully not as much waiting around. But then, that is always going to be the case with an event like this. They do say that in motorsport, one of the phrases often used is "Hurry up and wait"!
Hope to see you guys there. :action-smiley-069:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
