Hello,
I am looking to buy a metal part that connects to the Condenser in an R33 GTR, I am not sure how to describe it exactly but it could be like a loop that slides back and forth. If anyone has any pics they could send that would be a bonus because I can show my mechanic as he has more of an idea. It has been really hard to find so if you have all air con parts in tact perhaps a picture of that will also help, otherwise I might have to buy the full setup if it's all anyone can offer. I am in Perth so postage can be covered by me. Even if anyone can point me in the right direction that would be a huge help!
Cheers
Chris
https://www.sau.com.au/forums/topic/433857-wtb-metal-air-con-part-for-r33-gtr/
