It is time for me to finally get a family car :'( (tears in my eyes) and let go of my beloved GTR32....
I got back into GTR due to serious ugly temptations that i always had with my GTR's. Reason for selling is that I need a bigger car due to kids growing up and due to injuries, it is hard for me to put them in/out of the car...
History of the car:
Car has been in Melbourne for over 2 year, been imported by one of the local importers..I bought the car off the supplier and got the car registered as the first owner in Melbourne Car then showed 52000km++ on the odo (surely not genuine km's), currently sitting on 58,000km++.
When i first bough the car, i changed few things:
- Injectors (Currently running on GTR33 standard injectors bought from Racepace with receipt)
- Changed the wheels
- And cleaned the car in/out :)
The car is standard stock, not even been tuned yet. As far as the turbos, i haven't check them but i reckon they are not the standard turbo's. I said this due to the performance these turbo's have and it is running on 1 bar with no pinging. I will still not put my foot down due to being conscious just in case its running stock turbos...
About the car:
- First registered on the 28 Mar 2013
- Running on HKS Pod Filters (Also have the standard GTR32 airbox)
- 3" performance exhaust
- 18 inch/245 size tyres on all 4
- 3 spook rims
- Got the ACC valve cleaned when I first got it.
- Car has always been serviced every 5000km and also due for a service soon, which I will get done.
- Paint is fairly good for a over 20 year old car. No dint on the car etc.
- Interior is clean
Mild Issue
- the front left absober might need to be changed as when you drive on bumpy road, you hear some knocking. Might be some bushes that needs changing. Not a major issue
- Paint is good, not perfect for a 20 year old car. Few chips around the rear spoiler and bumper (pictures)
- Front bonet is a bit bent, not due to an accident. It was due to my careless mistake for not closing it properly and when the wind blew, the bonet opened and got bend a bit. You might be able to see it in the pictures. Not a major damage at all.
The car will be sold with no RWC due to the price and I don't have the time to find a stock exhaust and stock wheels and the time to do it. That is all needed to get the Roadworthy done. If i still have the RWC from the last time, i can recommend the same person to get the roadworthy done as he was fairly reasonable to do the Roadworthy (got to dig out the files to find it)
I am selling the car for $16000 as it is...SMS me on 0430024704 (LAV)...dont call as I am fairly busy at work. Car is located at Narre Warren and in East Bentleigh during the week on working hours. I also have few documents/receipt about the car and import papers.
https://www.sau.com.au/forums/topic/434145-vic-gtr32-year-1992-for-sale-16000/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
