I have a series 2 R33 GTS-t, it has OEM keyless entry. Key looks like this
Posted Image
I think it also has some kind of receiver behind the door card
Thanks! Big help! The key I got was a re-cut from one of those GTR keys you can buy on eBay. Do you know if the S1 got these?
I have keyless entry. although my key looks heaps different to Cassbo's
You have an S1? I just don't know when they started using them... Ugh! It'd be nice to walk up and not have to try to fiddle with keys to get in. You can tell that a key has been used for some time to get in cuz of all the scratches around the key hole.
I searched all over several forums and could not locate the correct method to program the key buttons my '98 GTS-T, so after a few days of trying every combination of steps located on 240sx, 300zx, and infiniti forums I came up with this: make sure all doors are closed, get in and lock the doors manually, insert and remove the key from the ignition 6 times within 10 seconds, the doors should then unlock to indicate it is in program mode, turn key to acc. position (do not start!) and manually relock the doors, press the lock button on the key once, the doors should then unlock again to indicate acceptance of key code. remove key, then get out and close the door and test the lock/unlock buttons. if the above steps were followed in order, all should work correctly!
Above quoted from GTR.co.uk. Does anyone know if the S1 got a keyless option? Searching keeps bringing up S2 and it was a common factory option.
its a DEALER fitted item. they didn't come with keyless until S3. it will be FAR easier to add an aftermarket unit to the existing actuator that is there and remove that mess in the door.
as for coding it - dont bother.
What I figured. Seems a lot of those remotes forgot to get on the boat with these cars. Aftermarket alarm it is..
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
