Lorne Cruise
Dr_Drift
 Share
The Great Ocean Cruise is on again.... and this time the Skyline Victoria Crew's invited to join us as well.....
When : Saturday 5th October
Meet: 9:45am Officeworks carpark in the city (230 ALEXANDRA PDE, CNR SMITH ST, FITZROY, it is just off the Eastern freeway)
Depart: 10am SHARP
Bring: Full tank of fuel and digital cams for photos/video
Should be nice wheather too
Whats the plan?: I am sure DRDR32 wont mind leading the pack with a few others to show us the way. Last time it was hard for some to keep together so we will have meeting points this time.
Meeting Point 1 : Geelong Maccas, it is located on Melbounre Rd, not hard to find we will be travelling in packs and I am sure you will notice a whole pack of imports sitting in the entrance if you are choosing to go slower. We can grab a bite, group up again and move on.
Meeting Point 2: Anglesea, not to sure where abouts but one of our leaders will be kind enough to find a visble spot for all to stop and let others catch up.
Meeting Point 3: Lorne. Here we will find a spot for lunch, probably the lorne hotel.
Now that we have done the boring part this is where fun will begin.
Now to those who are not keen on speeding, this is encouraged. There is no need to risk ourselves or others by being showoffs, just interested a nice scenic cruise...
It would be great to see all the faces of this group together for once.
ARE YOU COMING?
Doc.
  • Replies 40
'My names INARK and I'll be too busy whoring my A$$ to keep post count up while everyone else slacks off and let's the team down.... GO VIC!!!'
unless Dr_Drift is gonna do some drifting..I'll come :P
well despite my vote :)
*shakes the mysteriously magical 15ball*
"all signs point to THE LEFT! CANT U MAKE UR OWN MIND UP U LITTLE TWIT!! WHAT ARE U!!?? SOME SORT OF P*SSY!!!!"
last time i buy something for advice from the reject shop. ;)
EDIT**
oh yeah thats a HELL YEAH!!!
OMG THERE'S MORE THAN ONE INARK!!!!
EEEEEEEEEEEEEEK
/me squeals like a japanese schoolgirl n runs away
I dunno what my plans are yet, but I'll let you know closer to the day, that makes me a maybe for now. Sorry guys, don't wanna inflate the numbers.
i would bloody love to tag along guys, after just getting my line on friday morning, but she aint complianced yet, and i only have a permit, to drive a tiny bit(which i shouldnt be doing anyway)
so i will have to give miss, and come another time
make sure youtake many pics, and a vid again like the one up in healsville last time!!!
brad :burnout:
I'll have to give it a miss :)
The weather does not look too good, and I've been to great ocean road route at this kind of weather before and it was really disappointing.
Beside, I need to help my friend do an important research on parchment making, so I'll be spending my time from library to library today...
The weather was beautiful, nice cold air for turbs and coolers....
I wasn't spewing cause my speed limiter wasn't there..., herhehrh
You know the pointer next to the 0 km/h? Well my needle was pressed up hard beneath it for at least a few minutes hehehehe...
It was a great turnout, around 13 cars rocked up.
2x R32 GTSt
1x R32 GTR
2x S15 200sx
1x Soarer
1x Pulsar GTiR
1x S13 Silvia
5x S13 180sx
Thinks that's it.....
A few good pics from the day, still waiting on some video....
Here's a pic of a little fun afterwards
Doc.
 Share
    • Stock R33 boost control, with the exhaust, and FMIC done, will boost creep. There is no tuning around it if it is the factory boost solenoid.   If it has an aftermarket electronic boost controller, the settings/mapping can be altered in it.   Oil could be anything as mentioned, however did it ever do it before you did the turbo swap? How much and how often did you drive the car before the swap?   I'm hinging on too much oil supply, or it's not draining properly.   To check, pull the air outlet off the turbo. Is it full of oil? Drop the exhaust at the turbo, does it appears to be oiled/coked? Now pull turbo and check the exhaust manifold, does it appears oiled and coked the same way?   Secondly, the PCV could even be stuffed / not functioning properly and will cause blowing of blue smoke.
    • Almost any ECU would work, from a 30 yr old PowerFC to a new Motec/Autronic. But presumably you want new middle of the road ECU, meaning that you want a Haltech or a Link, most likely. As to which model though? I dunno. I don't keep track of what they have in their current ranges. You don't want a plug in though, because plug ins can start to cause you the same wiring issues that you have to chase up with your stock ECU/loom swaps when an engine transplant is involved. If you use a Haltech (and presumably a Link) you could put the base map for the engine in and drive it around and not even need to "tune" it. It will work just fine. I can't recommend a tuner without a location (and even then I can't recommend many, being as I never use any tuners except myself and my brother-in-law). And not many tuners are happy to remote tune. Maybe they'd be happier doing it for a basically stock setup that just needs to be demonstrated to be working properly. But even then, not being able to be with the car to see what the hell is going on and sort out the inevitable problems that will result from an engine conversion done by an amateur..... unlikely to be enthusiastic about the job. And if you think that just adding 2 wires for the boost sensor is difficult - you don't want to be trying to install and set up an aftermarket ECU. You're going to have to bite down hard on something with either approach.
    • wired everything up and confirmed that the red with white stripe is indeed the fuel pump pin on this harness.
