Hey guys, didn't know where else to post this.
Anyone here familiar with systems that can be installed for homes that have say 4 wireless cameras connected to something that shows them all onto a monitor and can record them all onto a hard drive?
Any suggestions on products or where i can buy good quality products?
Or if you are an expert and have experience installing them i would like to hear from you as well! (Will be getting something for my house very soon).
Cheers!
https://www.sau.com.au/forums/topic/434400-wireless-home-security-cctv/
I bought a couple of the basic wireless Swann units. They're very consumer focused (ie. simple to install and operate). They'd be no good for what you're after though. You can view them from your IOS or Android phone easily using the App. The sucky side is that there is no method to record anything to harddrive and they're pretty much trying to sell you a monthly recurring fee to use their 'cloud-based' motion recording system. You get a free trial for 30 days and as much as it works well - I hate lock-in recurring fees.
Edited by epoq
Ive installed cctv wireless systems jnto workshops and homes, id definitely say go wired, more reliable, no wireless issues but is more expensive to install...
Basically the more the you pay the better you get. Wired is the way to go, if you look at the high end systems they are all hard wired, in saying that though i have clients with wireless with access from iphone and it works ok...
Also look at the lens on the cameras as some have a wider view than others, so if the camera is mounted like 6m away from target youll need a view to be able to make it cover the most area
try using D-Link products, simple as bat shit to set up and buy like a Synology NAS to do all the recording...
alternatively you could build a PC specifically for recording all the wireless D-Link cameras, just pop in RAID1 with 2x 3TB NAS HDDs and a high effciency PSU and off you go.
I'm currently using a D-Link wireless 932L camera, works a treat.. automatic day/night with sound. I can remote into it from my phone and see/listen to what's going on and my Synology DS-212 NAS records everything
Thanks for the tips mate, definately keen to get wired installed, but in a 2 storey house i hear its going to be uber expensive.
I have thought about that, i have a server running freenas but i need external cameras and if they need power + ethernet, its pretty much the same thing to get installed lol.
Thanks guys, still looking but :D
    • bumping this post as im still having dramas, my fuel pick up is sitting on the bottom of the tank, my pump gets a constant 13 volts through a relay, my fuel pressure holds consistently without fluttering or dropping, yet as soon as im near half a tank of fuel my car starts fuel starving and leaning out, it cant be due to g force as it never pulls hard enough before it starts breaking up, any help would be much appreciated
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
