Hi Everyone,
I'm relocating from SA to Springfield Lakes. Can you help me with a suggestion of where I should go for a RWC and mod plate?
In another thread I was told my car looked low and that the cops would pull me up straight away. I believe my car is standard height and it's the illusion of the kit that give it the appearance of being low.
Here are the photos I took for the transport company
I can get 2 fingers in between the tires and guard front and rear. Is it too low?
Any help would be appreciated.
Cheers.
space between guards and tyres is not an issue, as long as the lowest point of your car (including the exhaust just near the diff) is above 100mm
What parts of the car need to be mod plated?
Everything is above 100mm (when checked on level ground)
I have no idea what needs mod plating (because I'm not familiar with your regulations)
My list of mod are:
Secured Apexi pod (not in a box)
z32 AFM
hard suction kit
T04 Turbo
Stainless ext. manifold
Turbo back ext. with hi flow cat etc. Not loud
Manual boost controller (22psi)
FMIC (metal was cut to accommodate the piping to the throttle body)
After market BOV that is 100% recirculating
Q45 Throttle body
Freddy forward facing intake manifold
1000cc injectors
Top feed fuel rail
Turbo smart FPR
Walbro pump
RB20DET ECU with nistune, running E85
permanent wideband lambda, boost, temp gauges to DLP-I08 and Consult
I think that's about it
You will need a mod plate for the turbo at the very least and the hole for the FMIC will probably need to be certed as well, as for the rest I'm not sure. The reo being cut will be a defect if it is found and can't be mod plated.
I know of a mobile mod plate guy on the northside but I'm not sure how far he roams to plate cars. As everyone said keep your SA rego until you have everything up to scratch.
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
