Hi Guys,
A bit of a rookie question but thought I would ask here before I do anything I regret. I'm just wondering where the best place to put my jack stands would be as I need to get under the car to do a bit of work and don't want to rely on a jack alone. I've taken a look around and I can't seem to find any definitive answer so just asking here instead.
This is currently where I'm jacking the car up from:
http://imgur.com/J8MgZWu
And am now unsure where to place the jack stands, I was thinking in this area here:
http://imgur.com/YwbQOz6
And to zoom in a bit more I was then thinking about placing them on this little ledge (just to the left of the red line), would this be ok? It's at the start of two beams which run down the length of the car but I don't think those beams themselves are strong enough to hold any weight as they do seem a bit soft.
http://imgur.com/0LE7OwN
Cheers for any help in advance
Edited by pdot
Those beams are not strong enough to jack or put stands under, they will crush and make your car unroadworthy.
Always use the sill jack points or the crossmember under the engine.
Here's the recommended lift points, but take care.
These are designed for an even lift, something like a 4-point hoist.
If you intend jacking up from a cross member and then transferring to these jack points via stands, you won't achieve the even loading that a hoist can.
You'll find one stand will take a lot of weight before the other touches.
I use the front tow hook and rear diff as jacking points. Haven't had any issues and it's on stands regularly.
I too have put the stands where the lower control arm mounts (as per 2nd pic) with no issues.
This is by no means the correct way, but works fine for me.
Edited by Kane_R32
Don't use the rails as there really soft, even the sill which they recommend are to soft for stands.
My old 32 had completely demo'd sills and rails from previous owners jacking the car up incorrectly.
I think it also depends on the experience of the bloke using the jack.
At some time I've jacked all my cars from the chassis rails and haven't put a mark on them.
I use about 300mm of 100x10mm plate to spread the jack's point load plus timber between the plate and the chassis rail.
But whacking a jack straight onto a chassis rail will guarantee a dinted rail, they're simply not designed for that.
I had a Rustia so bad I couldn't open/shut doors once she was jacked, it didn't matter where you lifted that heap.
Calling them a chassis rail is even a stretch, one side stop halfway down the car FFS.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
