Nah man. Was ordered two months ago. I'm betting late February if delivery in Japan works well with the container it's being put in.
They both have taller ratios.
Assuming a 265/35x18 tyre and stock ratios and a rev limit of 8000 RPM the speeds are as follow
Stock
1st - 75
2nd - 120
3rd - 180
PPG Helical and straight cut dog
1st - 89
2nd - 143
3rd - 189
OS GIKEN
1st - 87
2nd - 138
3rd - 190
Is the os giken speeds that you have showed are they the correct speeds even with the close ratio gear set? I would have thought that the closer gear set would shorten at least gears 2,3,4 and 5? Ow btw are those figures for a 34 ? Or 32 gtr?
Edited by boobeedoobee
The OS GIKEN 5 speed is most definately taller than factory gearing. That is assuming 4.11's in the diffs. Gts4 ratios will shorten that by 7% iirc.
What's the setup?
It would make the gearing awfully short with the 4.11's. You'd be changing gears like an Evo. It isn't the cheapest conversion to do.
Like he said what's the set up?
Set up is an r34 gtr getrag 6spd gearbox fitted to a 32 gtr .. it's the whole box including everything needed to do the conversation
By setup I meant what's the engine/turbo combination.
Boobee. The reason I was asking turbo/engine combo is that (and this is my opinion only) the taller gears in the OS set make a lethargic bottom end of a 2.6 L engine and make it even more pronounced.
For example, a mate on here on a pretty decent R33 GTR put one in and ended pulling it out and going back to stock ratios. That was predominately a track car too. 2.6 with -9's and -5's at different points.
Just something to think about.
Bakemono. Cheers man :D. Be good to drive it again lol.
Oh the lols
only do the Getrag if you do the 3.545 diffs as well, 1st gear in my 34 is now and always was useless even when it was a 2.6 with -7s, so add 4.11s to that and you may as well stay with the 5 speed as you won't use first with the Getrag
I can't wait to see the difference between 4.11s and 3.545s with the two identical OS88s once put side by side :D
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
