In Neutral you lift the reverse ring that sits under the shift knob on the shifter and push forward. Lift the ring and pull back to go back into Neutral.
  • Like 1
A few guys on the pommie forum have. One bloke by the name of Hugh Keir has an R34 GTR and the current setup is an OS 3.0 with twin HKS 3037's. He put the 88 in the car in 2007, pulled it out and put different ratios in it in 2009 and hasn't touched it since. It was a daily driver at one stage too.
How far off are you Paul?
Box was ordered 12 or 13 weeks ago on Thursday. OS say 2-3 months from payment till when the box is ready. Not sure is Christmas uaha slowed them down a week or two. I'd say it would be delivered to import monsters warehouse in japan within the two weeks then 1 month on a boat. Once it gets here it's full steam ahead.... Sooo 8 weeks or so?
  • 3 months later...
Who's using strain guages or shift cut knobs?
im looking at this one, any good?
Anyone using the holinger shift cut knob?
http://www.drenth-gearboxes.com/products/accessories/gearlever-strain_gauge.html
Edited by QUP29
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
