In Neutral you lift the reverse ring that sits under the shift knob on the shifter and push forward. Lift the ring and pull back to go back into Neutral.
  • Like 1
A few guys on the pommie forum have. One bloke by the name of Hugh Keir has an R34 GTR and the current setup is an OS 3.0 with twin HKS 3037's. He put the 88 in the car in 2007, pulled it out and put different ratios in it in 2009 and hasn't touched it since. It was a daily driver at one stage too.
How far off are you Paul?
Box was ordered 12 or 13 weeks ago on Thursday. OS say 2-3 months from payment till when the box is ready. Not sure is Christmas uaha slowed them down a week or two. I'd say it would be delivered to import monsters warehouse in japan within the two weeks then 1 month on a boat. Once it gets here it's full steam ahead.... Sooo 8 weeks or so?
  • 3 months later...
Who's using strain guages or shift cut knobs?
im looking at this one, any good?
Anyone using the holinger shift cut knob?
http://www.drenth-gearboxes.com/products/accessories/gearlever-strain_gauge.html
Edited by QUP29
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
