Roflmfao. GTSBoy. I work with lots of japanese cars in freeport bahamas. I also work with lots of germans and yanks at my work place FCP (freeport container port) Its funny to be able to do both, but I totally understand your point. As I always hear good comments from both sides.
That was classic as I hear it all the time. Its funny how each person from a different place knocks the other system. But are advocate to the system they learned.
But ignoring that aspect, one system makes sense (ie, is self consistent) and one system is based on random factors and makes no sense at all.
For example. Torque. All SI torque is expressed as Nm. Really small torque you just call it milliNm or 10^-3 Nm or micro or nano or pico and the same going up in the opposite direction. Here, it's ft.lb (or lb.ft for those who don't even understand their own system!) and then for small torques you drop down to inch pounds.....but there's a factor 12 in that conversion. I guess that if you want to go to really small torques, rather than do anything else, you'd change from pounds to ounces, and there's a totally different factor of 16 there. So ounce inches are numerically similar to ft.lbs but not quite. But here's the kicker. Pounds and ounces are not even units of force!!!!! Except that it is, Except that it isn't. Except that it is. But it isn't. Because it is used for both, but no-one ever specifies which they actually mean! So when an American says to me "60 pounds of air", they're probably talking pressure, meaning psi, but they never say psi, just pounds, and of course anyone from the rest of the world expects a pound to be a unit of mass. It's no wonder they crashed that probe into Mars a couple of years ago. The European rocket scientists and the US rocket scientists were lucky to even agree on a launch velocity.
That is the pattern of every single unit in the entire system. Everything plays by its own rules and to hell with the rest.
I understand that the case hardening on nissan shims is about 0.02mm and rubbing them back is not a great idea- hence swapping them around to to help get correct clearances rather than rubbing them back. Precision Shims Australia (in Melbourne) do shims with about 0.2mm case hardening and come in increments of 0.02mm, so can be rubbed back 0.01mm no probs. And they're almost half the price of nissan oem. I get new shims from there almost every time I do a head as the standard ones taken out are usually pretty mushroomed anyway.
With bucket over shims, it doesn't matter so much if you remove the hard layer on the top side because the load is spread across the whole shim face. Putting the rubbed side down on the valve stem is less good. But I do otherwise concur that it is better to get new ones than linish old ones.
GTSBoy you mentioned that you have done the sand paper method before. ??
How did that work out for you. Is the motor still running. Do you also agree that the first .002 mm is hardened material. ????
Never the less if the shims were sanded down what might be the effects of doing is. On the valve train this is. I had some extra shims and cut one in half, but it all seems the same to me.
Do they mean the shims are treated to be harder.???
Can some one also post a link to were I can find custom shim made at spesific sizes.
Thanks.
I havent heard of case hardening ever being that thin. usually it is around .2 and surely .02mm would be pointless as case hardening. Unless it was .02 inches thick ;)
^With the .02mm case hardening- Just what I've heard after looking at options to replace oem shims (after finding out the price of oem I was looking at rubbing down the stock ones I had..) Chris at precision shims is a good bloke, happy to chat with you about what you need. All sizes/prices/contact details etc are on the website www.precisionshims.com.au Not sure of other places that do custom/aftermarket shims.
Thanks.
Alfa Romeo engine, last century.
  • 6 months later...
Ok I just finished up the valve clearance on my build. Sorry it took so long I was waiting on a new crank.
Well what was good about the whole thing is once I mesured tye first time and found how much I had to take of the shims I only had to install the cams once and they all came into specs.
One of my questions is. I noticed that some are just a bit off eather a little slack or a bit tight no more that .001 will this be ok.? I have them on a big peace of card board. Check the attached. Its a little getto I was planning on cleaning it up and posting it but im feeling sleepy. Lol.
The exhaust side at the bottom is the finishing measurements. T under the numbers means tight. Im hoping this is ok. ???
Edited by MJTru
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
