Hi guys I replaced the timing belt on my 34 today once I got it on I put the cas back in and gave it a quick run with nothing connected including the harmonic balancer not being on I only ran if for about 5 seconds and when I have gone back around the front of the car I noticed the timing belt had come halfway off the gears and crank cog I was just wondering if anyone has any idea on what it could be eg to tight? Or is it that the large washer thing that goes on behind the harmonic balancer wasn't there to hold the belt in place? Any info would be much appreciated
https://www.sau.com.au/forums/topic/435125-r34-timing-belt-slipping-off/
could be a number of things:
  • the bolt holding the tensioner OR idler is bent
  • Belt under/over tightened
  • crack plates put on wrong
  • cam wheels not on properly (backwards even)
to tension belt, put everything on but don't tighten the tensioner, crank the motor by hand (only by hand) for 2/3 revolutions. The spring on the tensioner is enough to pull the slack out, then tighten up tensioner in place. Rookie mistake is under tension. End result after motor starts, there should be about 1/2 a twist of the belt in slack
The guide not being there is the problem. You are heaps lucky it didn't actually come off.
this. damn, so close.
my mate did this and he reckoned it was about 10-15 seconds before the belt came off lunching the valves with the pistons and ending the otherwise healthy motor's life.
be careful mate.
  • 1 year later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
