Yes Humbla is correct!
As experiments, she deliberately drives on country roads to collect bugs on her bumper > she has proven how Turtle Tar & Bug Remover is best at dissolving insect blood, intestines, appendages and gore > she stands back 2m and realises that her front bumper is cleaner than the rest of her R33 and Buddy Clubs > she cannot wait for a thread like yours to relay her delirious joy!!!
https://www.sau.com.au/forums/topic/435371-bug-guts/#findComment-7118840
Haaaaaaa haaaaaaaa Terry you crack me up. :rofl:
https://www.sau.com.au/forums/topic/435371-bug-guts/#findComment-7119877
  • 3 months later...
  • 3 weeks later...
Turtle wax bug and tar remover,easy to use works fantistick. :yes:
yeah its good stuff....But don't let it soak on your badges for too long as it can melt the glue and you end up with missing letters as I found out the hard way when i turned a STAGEA into a STAG :/
On the bright side, if you do want to de-badge your car its a good start ..
https://www.sau.com.au/forums/topic/435371-bug-guts/#findComment-7252465
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
