Little Bit Of Help Please.
skylinedreamer1
 Share
Hi, I have a few problems with my r33 gtst series 2,
First I have no tacho or boost gauge. (I don't know if the are separately fused from the rest of the dash)
My turbo timer has stopped working :/ (I have had the stock computer changed to a microtech ltx-12)
After I have been driving the car for a period of time, I get the red flashing light on the ecu as well as the constant green, and it looks to be like the orange one is flickering.
Any help would be gratefully appreciated thanks :)
There is a map sensor in the rear right of the engine bay which is for the boost gauge. Check it out.
As for tacho, might pay to check the wiring at the back of the cluster. Might just be a simple issue. Check all fuses as well.
Also you can check the ECU plug is in properly and there are no wires cut (someone may have spliced into it for some sort of external tacho etc)
I got microtech software and cable - red light means error - I can check it for you if your in Sydney and willing to come to me... Yellow light on crank is fine but if while drivin means your throttle body needs to be calibrated!
 Share
