My car is coming up to 100,000 kms, what should i be looking at replacing? Its also due for an oil change & new filter & fuel filter too.
Its a '96 GTS25T with stock boost and just catback and pod.
What oil/filters should i use, and what other part need replacing? I am in auckland, nz.
Many thanks dudes :P
https://www.sau.com.au/forums/topic/43568-general-maintenance/
Ryco filters. use 10W/40 synthetic (or semi synthetic oil). I use Motul 4100.
change: water pump, timing belts, sparkies. Flush radiator if you haven't already, same for brakes (use Motul DOT 5.1 or higher grade brake fluid). Clean the pod if you haven't already.
do what you're confident with to save money. 100K services are never cheap if totally done by the mechanic.
Try and source the parts if you can. Nissan will charge an arm and a leg for Skyline parts. Take it to your mechanic (if you have one) to do your brakes etc...
yes all you said above in changing timing belt,water pump ,oil filter,sparkies ALSO change your idler bearing approx$300 from nissan oh and by the way DO NOT use an aftermarket water pump as they are inferior to nissan parts, also you may need your computer re set on the nissan consult or your idle will be erratic. if you have powerfc dont worry, good luck guys i just recovered from the bill.
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
