Selling my Original Speedy Spyders (rare not made anymore)
18 x 8.5" Rims with dish and offset to suit Skylines, Silvias and Fords
A small amount of gutter rash, small flat spot inside left front rim, however you cant notice it even at speed, and some small chips on the rim (fixable)(see pic) which was made by the shop who installed my new tyres..
Ive owned the rims for 6-7 years, and they have been really good. cost me $1,500 back then. They are currently on the car and to prove the condition they
will be on the car this weekend at the track.
These are a pretty decent mid range rim, not the lightest but they are strong.
Will remove once buyer has made downpayment
Asking: $400 ono
Price is for rims only, no tyres. however I can add a set of Potenza RE 050A street tyres 75% tread for an extra 250$
600 x 300 x 76 KLS Japan Alloy Intercooler
Type: Bar and Plate
Condition: used this for about 5 years, still in very good condition
item is clean and sealed ready to go.
will suit almost any vehicle
Asking: $100
RB30 S2 Engine
I have a RB30 S2 Engine here, including head
everything good on this motor except for the crank.
$300 for the lot
RB25 Head ready for 30/25 conversion
Fully prepped 25 head
Crack tested head.
Boss welded and tapped for side VCT Feed
VCT Feed on port face welded and head decked
Full valve job, all new Vavle stem seals
all relevant welsh plugs welded, and head cleaned and checked.
comes with stock cams and lifters
$2k + worth of work . receipts available.
asking $750 ono
3e51.th.jpg[/u
RL]
R33 Skyline Cam and Valley Covers (RB25)
Asking: $150
As you can see, full set of RB25 Covers Wrinkle painted, and valley cover meshed. (same head as above for sale)
Jim Berry Single plate 6 puck carbotic clutch with balanced billet flywheel
700hp rated
asking $200
K&N Pod (cost $160)
Still really good condition only used for about 5k kms.
Asking: $30
2.5 Tonne Workshop Jack
6 years old, really reliable strong, cost $260 new
selling for $120
nothing wrong with it, just need a slimline one.
Stock R33 GTST Swaybars
Front and Rear good condition with rubbers 50 bucks for both.
stock R33 GTST Cams
I dunno?... $40 no scoring, ready to go.
[url=http://imageshack.us/photo/my-images/145/rb25detcams.jpg/]rb25detcams.th.jpg
All reasonable offers considered.
Call or SMS 0432279166
  • 1 month later...
  • 2 months later...
  • 1 month later...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
