hey guys had a bit of a search but couldn't find my answer.
ive installed a plazmaman throttle body and plenum
I hooked a compressor up to my intake to pressure test the system whilst doing so found that it was leaking around my tps.
I removed it and sure enough there was a fair amount of air coming out from the end of the throttle shaft seal. it starts to leak at about 14psi and gets worse up to 22psi where I stopped as that's around where itll be getting tuned at.
just want to check if this is normal.
I called plazmaman and they told me that its completely normal and it wont be noticed also that I shouldn't have been doing this as its a static pressure 20psi and so on.
any input from experience would be much appreciated
It shouldn't do that. I can accept that no seal is perfect and that there might be a small leak, but if it is a lot of air, then that it wrong. Having said that, what you think is a lot of air and what I think is a lot of air are likely to be quite different.
In addition, kick the Plazmaman phone person in the snatch for being stupid. There is no difference between being put under 20psi internal pressure on a purely static basis and having the air flow past. Knobheads!
lol well it does seem like quite a bit of air to me but who knows, I guess when it goes in for a tune up ill see what unigroup think.. I didn't think there should be a difference with the static vs dynamic thing but didn't want to seem like a knob head arguing the point if I was wrong
haha I gave the fitting I used to hook up the compressor back to its owner.. on my hand it felt like the amount you would expect to come out of a 1 or 2mm id hose at that pressure.. not the most accurate guess but a worrying amount to me, even with the tps on you can feel it blowing out on your hands.. my hands are all that sensitive either, no cheek up against it needed
I would make sure there are zero leaks before taking it to them. In fact you want zero mechanical issues when you arrive there so they can smoke it and get on with tuning unhindered.
Time is money and it only ends up frustrating for both them and you.
I realize this wolverine but how am I to determine if this is an issue when the manufacturer is saying its normal and not to be worried about.. without getting a second opinion from someone who knows what there talking about such as yavus or mark at unigroup
it was alex I spoke to, he was quite helpful through the original purchase stages.
How would I have it proven to leak for them when they dissaprove of a static pressure test.. btw just to check before this goes further, the regulator on the compressor was showing quite a higher pressure but my assumption is that it was leaking out the valves as both my boost gauges in the car where what I took the readings off..
Yeah might do, I would prefer to have a definite that it's an issue first before complaining getting a new one and finding its the same.. i I called yavus he said it is normal and more common in aftermarket tb's as long as it's not excessive.. I have a feeling this may be excessive though
Yavus is going to tune so if he is happy with it then you should be sweet.
I have had cars back and forth from tuners over the years due to minor niggling issues and I was always lumped with the bill so I am a big fan of taking a week or so extra to get the car 100% mechanically right before tuning.
Yeah I would definitely like to have it 100% but I don't have any other way of having it tested, unless you have suggestions..
The car was being tuned and with a couple of other small faults, he said there was a loud hiss with high boost so I'm trying to find it, it was originally thought to bbe around the intake runners but with the compressor and some soapy water I think I've eliminated that, I found that I accidentally put the check valve in the wrong way for my carbon canister solenoid so I fixed that which was making noise with a bit of pressure from the compressor. I'm hoping that was it if not it must be this tb. I don't think I have another option other than back to the tuner
They already did smoke test it, couldn't find it as the smoke test only goes to 5psi and it doesn't pop it's head until beyond that, not sure if me testing it cold allowed it to not show itself I figured cold would be better as nothing would have expanded..
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
