2860 ~5s with GCG 18psi actuators (the best ones imo) and heavy duty bracket so there's no flex and boost line is very straight with great control with no drop off at the end,i also have modified inlet pipes that bolt to the front of the turbo plus made an insert so there's no step into the turbo which makes them flow like the HKS 2530s and increased spool up dramatically $1500
Ported and flowed and match ported stock exhaust manifolds to maximize spool up $250
Tomei Expreme dumps latest ones used $450
Apexi front pipe dual 70mm into 80mm $250
Power FC for R34GTR with handset $750
Sard 700cc injectors $400
Z32 afm's with plugs in as new condition $400
R34 gtr airbox complete with cold air inlet duct modifed to bolt on z32 AFMs like stock AFMs $300 or $650 with complete with Z32 AFMS and plugs
Stock airbox complete with stock AFMs plus cold air inlet $350 or $250 with out AFMs
Custom alloy pipes to replace the twin turbo pipe just like the nismo style but a 1/4 of the price $450
Drop in Trust cams 264 duration with 9.1 lift $250
JUN oil pump $700 pump has been thoroughly inspected and crack tested the gears are like brand new! i bought a tomei one for the right price so i swapped them over
Trust intercooler 75mm to suit R34 GTR perfect condition $500
For R32GTR there is a brand new Power FC $850
Mines style rocker cover baffels brand new (may be genuine Mines i just cant remember as i bought them a long time ago from justjap) $220
Brand new nitto head gasket 1.2mm thick $300
Engine mount $50
all parts done aprox 6000 klms (unless stated otherwise) made 340 klw at 20psi full boost at 4000 rpm on pump fuel,gone to a single turbo set up now there for selling the lot
located near Gosford NSW i can also meet up on the northern beachs in Sydney
​will post at buyers expense and if you want to pay with paypal thats fine as long a you cover the fees on my end
Hey mate , are the cam baffles for sale? Can't see price or info on the ad. Interested on exhaust manifold as well. Pm me.
Thanks Ryan
Edited by wld093
These pipes and the insert are easily removable and the pic where im holding the short pipe is the unfinished product it was just showing the mesh welded in the part coming from the blow off valves,the pipes look factory after i finished them i will post more pics tonight
The Trust inter-cooler is the older style which were the best by far ( the current ones are made in china i believe) it will work great on any engine making up to 400 klw at all 4 wheels it has cast formed tanks and is perfect for track cars or street cars,when i swapped to the nismo 100mm cooler boost def came on LATER and inlet temps were no different on my MFD
VERY HARD TO FIND THIS VERSION!
For those who wanted to know if the baffels are aftermarket they are actually GENUINE MINES TRIPPLE FLOW items selling as a complete kit
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
