plumb the wastegate back into the exhaust and it will be quiet again, are you running a stock turbo cause it sounds like it..
Not stock turbo, pretty sure it's a ebay turbo (Was there when i bought the car). [i'm aware the oil feed line isn't the best and i'm ordering braided hose for anyone about to comment on it]105y99l.jpg
I've done some research and some people use moto exhaust silencers plumbed to external to quiet it down, anyone done this? also can i change the way the gate opens? i'd prefer it at higher rpms oposed to when im just trying to overtake people.
Edited by iTwix
someone shoot me. please.
Hey man, you had to learn at some point too. I know alot about n/a engines but i'm fairly new to turbo's although i'm getting there. Why do skyline drivers always condescend on people :\
Edited by iTwix
Don't worry about those people. Majority of them are kids sitting behind a computer ragging on others ignorance to make themselves feel like their dick is bigger. Learning takes asking questions.
I'm gonna guess that silencer you're referring to would kinda work. It's called a SuperTrapp. Good mufflers and tunable depending on how many rings you run. Seems like a lot of trouble and not a whole lot of room to do so. Google SuperTrapp and look for the dimensions. Measure it out. Before you start playing with spring rates in your waste gate, probably want to look at howstuffworks.com and search turbo. It will help you understand majority of the basics and some advance calcs on forced induction.
But when it comes down to it and a lot of others are explaining to ya....plumb it back into your down pipe. I'm sure any muffler shop can help.
Thanks man, i appreciate the helpful post. I think plumbing back to downpipe may be the best option, what is the horsepower difference? I started around 320hp and it feels like i've lost about 50 hp with the gates current setup, will downpipe plumbing effect performance oposed to exhaust vent to atmo?
Edited by iTwix
Have you tuned it yet since installing the external?
Not yet, i have a microtec lt-12 ecu but don't have the plug play cables yet to edit setups.
Also noticed you're say hp instead of kW. You must live in n. America.
I was originally living in canada but i'm living in perth now.
Edited by iTwix
Doing a waste gate upgrade like that requires tuning. You went from whatever internal which is normally 5-7psi (unless you have a boost controller) to whatever you received the waste gate as from manufacture. Externals are much more adjustable and tunable. That's why an external waste gate was engineered for, to gain more options for tuning. A lot of people don't realize how much that spring inside can alter your turbos personality. You really need to get the car professionally tuned if not done yet.
One of the reasons i haven't dumped the car on a shop yet is a pride thing, when i got the car i had to do alot of work replacing hoses and rerouting things properly (there was no nipple for boost on turbo or in piping) causing it to boost cut really bad. You can see in above pic that my oil feed is pretty sad, needs a 90 degree fitting and braided hoses to avoid kinks/melting. Couple hoses had some shocking frays and was dripping little bits of oil. So i'm making sure that everything is in good nick and wont be an issure before milking power out of it.
Another reason would be the cost, i simply don't have 1 grand to drop into tuning right now and am saving my pennies until i can get there, until then i'll be working on it the best i can learning as i go.
(pic is oil return line from turbo, one of the many pipes i've been replacing with proper silicone heat resistant pipes).
lol....typical noob comment...
lets put it this way...muppet removes exhaust pipe at engine...then complains engine is too loud...and we are meant to take him seriously....?
lets put it this way...muppet removes exhaust pipe at engine...then complains it is too loud...and we are meant to take him seriously....f**k off...
i didn't remove shit, i'm dealing with what i got. You have a high post count for someone that spits usless info, why don't you put it on your resume and see how far your condisending attitude gets you in life.
Edited by iTwix
Yo people,
My problem is that my R33 gts is way to loud after hooking my external wastegate up. My skyline has a straight through exhaust which is loud itself, but not overly loud. When i hooked the waste gate up it made such a noise that it pissed off anyone within a mile of me,
well thats not what you told us is it?
At what point did i remove anything? wastegate was already hooked up to exhaust manifold, just didn't have the nipple on the pipe from the cold side of turbo routed to the wastegate to add pressure to open it, meaning it was boosting uncontrollibly and fuel cutting/backfireing when it overboosted. Hence the need for the wastegate to be hooked up so it can releive pressure, yet i'm discussing ways to silcence the wastegate noise as it's obviously noticable as external atmo gates are. You can add your opinion about the car, not about people in the thread because who the f**k cares about that.
Edited by iTwix
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
