being on the south side it will be half for the cruise and the other half to get there,am keen will have to see how christmas goes,and the money,but what a drive it will be,half way in the car already,lol.
Judging from my fuel consumption on Sunday i may need to bring another 100L
Yah I used a whole tank on the track Sunday LoL
Put a couple jerry cans in and still need to fuel up,
before the Paul Walker cruise.
I was the same. Went through a tank and a bit and still stopped off on way home to fill the tank.
Sort of how my happy laps videos make me look. That's why I have the camera rear facing now.
One of my biggest memories of SAU Happy Laps was driving like a boat around the corners only to look in rear view mirror to see and angry man in a 33 right up my clacker trying to get a good run on me lol....
Only because I didn't have a hope in hell of passing you on the straight, I was having a lot of fun watching you wrestle your boat around the corners.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
