Ok Guys Upgraded to single turbo so I have a heap of stuff up for sale all from my 34 GTR
$150 Venom 3' Cat
$300 trust Greddy front pipes 70mmx2 - 80mm
$300 34 GTR Intercooler
$550 AFM Z32 80mm
$150 34 GTR Stock Intercooler piping
$500 Arc Airbox
$300 34 GTR Stock Dumps
$300 34 GTR Exhaust Manifolds
$1700 34 GTR Nismo Weldina NE1 Exhaust Turbo back
$1000 34 GTR Trial titanium exhaust cat back 80mm
Also have my twin turbo setup off my GTR that I want to sell as a set as it will benefit someone more, willing to separate at the right price if I have a few buyers wanteing the other parts. looking to get $5000 for the whole set.
GT2860-5's
Greddy Intake piping kit
HPI 3" Dumps (turbo x coated)
Racepace equal length front pipe 3''x2 - 3.5" (turbo x coated)
all items have only been on the car for about 7000km,
the hpi dumps, and the racepace front pipe have only ever been test fitted, as I changed my mind half way through and decided to go single turbo on my GTR
Items are located on the central coast, but can bring to sydney for serious buyers, can ship items at buyers expense.
Contact on here, but would prefer Call or TXT 0409076032.
Kane
  • Like 1
https://www.sau.com.au/forums/topic/436597-rb26-parts-34gtr/
Hey mate it's 80mm :), also comes with custom made mid section if you think it's too loud for you, see pics to understand what I'm talking about, sound real tough though! I was making 324kw with it and had no issues it, so you can gauge a power rating :)
ok Guys im sick of having so many car parts lying around I just want them gone,
price drop on a lot of items, give me offers if you like.
$250 - 34 GTR Stock intercooler
$500 - Z32 AFM ( only done 4000km)
$100 - Stock intercooler piping
$450 - 34 GTR Arc airbox
$250 - 34 GTR Stock Dump pipes
$250 - 34 GTR Stock Exhaust Manifolds
$1600 - 34 GTR Nismo Weldina NE-1 Exhaust ( same as Z-tune exhaust but stainless steel turbo back )
$1000 - 34 GTR Trial Titanium exhaust ( only done 4000km also comes with extra centre muffler see photos )
also I will part the turbo setup.
$1800 - GT2860-5's ( only done 4000km )
$900 - Greddy Intake Piping kit with Hks AFM Deletes
$600 - HPI 3'' Dump pipes ( Black Ceramic Coated cost $200 ) brand new only ever test fitted
$1000 - RacePace Equal Length Front pipe 3''x2 - 3.5" ( Black Ceramic coated cost $300 ) brand new only ever test fitted
Soon to have:
34 GTR Power FC
Bee*r Limiter
Edited by kaneryan
!!!PRICE DROP!!!
$300 - ARC Airbox 34 GTR
$150 - Stock Dump pipes 34 GTR
$150 - Stock Exhaust manifolds 34 GTR
$1200 - 34 GTR Nismo Weldina NE1 Exhaust
$850 - 34 GTR Trial titanium exhaust
$1700 - GT2860-5s
$700 - Greddy intake piping kit
$500 - HPI 3" Dump pipes ceramic coated never been used
$800 - Racepace equal length front pipes 3"x2 - 3.5" ceramic coated never been used
Soon to have
$150 - Bee*r Limiter
$800 - 34 GTR Power FC with hand controller
Come get em!
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
