PRICE: $1200 ono without afm and pods
CONTACT: txt 0438016754
DISCRIPTION:
today I have a fully custom rb26 twin high mount setup for sale! the kit includes
2x custom high mount manifolds
2x custom dump pipes
1x custom Y pipe
2x custom intake pipes (rougher quality compared to the rest of the kit)
2x custom oil return hard lines custom and very accurate
1x custom intake Y pipe
2x great condition rb26 r32 stock turbos with minimal to no shaft play
fully custom water and oil lines with lots of speed flow fittings
can include twin z32s and pod filters to match for extra
also has any other parts you can think of for the turbo setup that I may of forgotten
this kit is an extremely custom rb26 twin turbo high mount setup that all lines up perfectly and works extremely well, the kit it currently bolted up to my rb26 setup so visual inspection is available along with seeing the car drive, a deposit will be required before removal of the setup
the waterlines are a fully custom setup with a lot of speed flow fittings and a few cheaper fittings because they ran out of speed flow fittings at the shop, a few of the lines where damaged when I ran them a bad way but there is no leaks or anything just visual damage.
I am upgrading to a large high mount single turbo setup so I will consider swaps for a large genuine turbo or a nice single turbo manifold for a rb26
Edited by rb26 r33
  • 1 month later...
  • 4 months later...
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
