eoi.
built rb26/30
block
arias pistions
spool rods w arp 2000 bolts
linished std 30 crank
spool crank collar/ extended oil pump drive
greddy hv oil pump
n1 water pump
tomei oil restrictors
arp head studs
acl bearings
genuine seals, f/r main
head
completely reconditioned r33 gtr head (Advan)
spool rear oil drain
tomei pon cams
adjustable cam gears
hks head an manifold gaskets all mls
sump
rips 7l
hot side
6boost mani
garrett gt3582 w .82 rear hsg. & anti surge front hsg.
turbosmart 45mm race gate
dump+screamer suit 33 gts-t
fuel
greddy fuel rail
id 1000 injectors
ignition
splitfire coil packs
clutch
os giken twin plate
to suit rb25 gearbox
engine management
link g4
tuned making 370 rwkw with this engine
engine was built 14 months ago an now has 8000km on it
any test welcome was looking for 15g with everything above
would be a good drop in package for an r33
cheers
https://www.sau.com.au/forums/topic/436821-built-2630-eoi/
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
