Im a newbie when it comes to all the skyline sort of things, well, pretty much cars all together.
Ive run into a problem with my r33, and am definitely in need of help.
It seems to sound like a miss when its on idle and its also spraying some clear liquid out the back which is combined with some sort of dark grey/black residue? I think the word for that is. Anyway, any help on the matter would be much appreciated. Thankyou.
The liquid will be condensation/water vapour
NOT unburnt petrol
Its dark coloured because the water is picking up the carbon and ash that is sitting in the exhaust pipe
Agree - more so if parked outside but will happen when air pressure is pushed out and when there is heat applied to cold (Condensation)
May still have a misfiring problem but that has naught to do with the clear fluid with grey/black coming out of the muffler.
Unburnt fuel comes out as fumes
Edited by Sinista32
You guys can argue the point all you want but my car is currently having this issue... Cylinder one is not firing and therefore on cold start it spills out some unburnt petrol. It gets so bad that it even leaks out of my cat!
It may not be his problem, but I'm just pointing out possibilities. Also take note of the fact that in 30+ degrees temperatures your exhaust condensation is very minimal.
To me this reeks of head gasket and iv even had exactly these symptoms in a car I had years ago that did the head gasket.
If you let the car idle long enough to heat up does it still keep putting fluid out the pipe? If so, quite likely HG...
^^no one is arguing the point here. . In your case id be more concerned about the fuel diluting your oil than it leaking out the cat
:) I totally agree - and if you smell my dipstick it smells like petrol!
  • 4 weeks later...
Mine did this on cold start before tuning. Havent really looked since the tune but it was just condensation, clear liquid with carbon bits made it look black. Not coolant so had to be condensation
I'd say if it goes away once it warms up a little then its probably just conensation
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
