Hey guys,
Installing my stock boost controller this arvo and just needed to know where the hoses go.
From my research all the photos show the stock controller have a T piece that goes on one of the hoses, however I am missing that bit.
So the controller has two outlets on the top of it. Which goes goes to which part.
Actuator:
Boost source from intercooler:
Cheers,
Daniel
https://www.sau.com.au/forums/topic/437023-stock-boost-controller-install/
Boost source (normally off cooler pipe) to a T piece.
From T to actuator.
also from T to solenoid.
From solenoid to BOV return pipe. (but you have cut off the bit of Bov return that has the nipple on it so you can use your metal intake pipe. YES?)
Inspection passed!
But not sure if this is connected correctly. Currently have a hose running from intercooler pipe to the bottom nipple on the controller. Then hose running from actuator to top nipple on controller.
Correct? Or do I need to source one of these T pieces for it to work correctly
  • Like 1
Incorrect.
You need the T piece and Nipple on the BOV return to be able to bleed off the excess boost pressure.
as you have it now, you will have NO pressure going to the actuator untill 4500rpm and then MAX pressure to the actuator but no bleed at all.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
