hi I just finished my installation of my holset hx35w on my rb25neo.running it top mount an externally gated just finished if off today an I have a problem it starting to blowing smoke I had the turbo checked over before it was installed it had next to no bearing play front an rear wheels were in excellent condition no scratching or chips we had the turbo apart an it had no signs wot so ever that it had oil being blown out of it now since I ran the car for about a hour an an pulled of my air intake an intercooler pipping an wipped it with a paper towel an there was no signs of oil residue any were I can't work out why it's blowing smoke wan it was installed I made up new 19mm oil return lines but as for the oil feed I'm still using the original solid rb25 oil feed line any help would be appreciated cheers
https://www.sau.com.au/forums/topic/437027-need-help-on-holset-hx35w-on-rb25/
first off as for the smoke at idle its minimal to none that I give it a hit it blows a lot for about 2 seconds than dies down to almost nothing again I unscrewed the o2 sensor an it did have a little oil on it....
as for the next question I believe it's a journal bearing an I was goin to buy another oil feed line tomorrow an see if that helps it at all
I will get a new oil feed line tomorrow but could it be that the oil return line is to small from wot I've red up these turbos do need a pretty large oil return line... is there anyone else that has dun one of these turbo conversations lately
You will need a oil restriction free feeding line for this turbo. Factory oil line has a oil restrictor in it, might have damaged the bearings already.
Get a proper dash 4 hose with speed flow connectors for the feed.
Make sure the oil drain pipe is not capable of storing any engine oil any where.
Make sure engine breather can breath freely (photo have shown that it is), crank case pressure can also cause oil flooding issues to the turbocharger.
If above don't help then this turbocharger do needs to be looked at.
  • Like 1
yea from wot I've red up using the holsets u tend to need to use much larger oil return lines... wot rubber line do u use as a oil return
I dont use a hose ive got full steel line i made up with id 19mm with one continoius bend going into a 45 degree silicon joiner off tge block. I dont trust hoses on high mounts since they sit to close to the manifold.
thanks for the help guys I really appreciate it I'm hoping the turbo hasn't been damaged I've only ran it for about a hour an about 50min of that was it sitting there idling but after that I pulled of the intercooler an air intake an there was no sign of an oil in it is it possible for the turbo to have a blown seal an only be leaking out the dump pipe... will upload a pic or the oil return tomorrow an see wot use think
that's wot I made up aswell a solid 19mm steal tube an a 90 degree bend using a rubber hose at the block
Yeah if u only blow rear seals it will only leak into exhuast. Just out of interest what size return did u read holsets need?
every were I read just recommended using a larger return just due to the size of the turbo
This is the best advice. Stao knows his turbo problems, and has seen quite a few bush core highflows fail from lack of oil flow. The stock banjo needs to be drilled out at the very least. I go 2.5-3mm usually, drilling through the .9mm stock restrictor.
I have seen a bush turbos fail within 50k's from similar stock restrictor issues. At least check the shaft play both ends of the turbo.
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
