Thanks for the heads up. Apparently the D1 quick releases are the way to go.
I had a D1 on the old boat, only problem was it made the steering wheel sit to far forward, and even with a short boss on the 5 a D1 would be to far forward and put me in a somewhat cramped position for driving, which would be bad.
Works bell make a short release which may be a option.
Hey mate there is a really narrow one now available:
http://justjap.com/index.php/d1-spec-slim-steering-wheel-quick-release-black.html
I have one here, if you have the other style I'd be happy to swap (because I prefer the deeper style). It is 22mm deep vs the old style which is 56mm deep.
  • 5 weeks later...
Not much happening car wise, tax time soon so updates will abound, meanwhile whilst being bored and having some alloy sheet left over from the CAI box I made up a lower section for the radiator to stop the air taking the easiest route and passing under the radiator.
Put in some void spacers (like pineapples) into the diff bushes, there was a knock when hitting rough roads, they were cheap and I was bored.
Turns out the knock was from the hard top banging about, tightened up hardtop and fitted some rubber bushing in the latches and fixed the knocking on rough roads.
LOLOLOLOLOLLOOLLOLOLOLL,LOLL
  • Like 1
Got another power steering rack that I am in the process of depowering.
Why, I took a non power steering MX5 for a drive and liked the feeling better than power assisted.
Its a easy enough thing to do, a little bit of fun with a grinder and a lot less clutter in the engine bay.
Plus I remove about 8kg of weight which while not a lot is still weight loss.
  • 5 weeks later...
Need to fab up a better air box, moved from cold side to hot side due to torque loss, the little girl needed more intake length for her to run at optimum. .
Also new wheel and quick release because I wanted to waste some cash which should have gone to the diff fund.
It seems that scuffing and cleaning with grease and wax remover isn't enough for the VHT manifold paint to be happy enough to stick to the headers.
I blame the blue paint stuff that the headers were coated with from new, I shall leave it for a while and hope that the heat gets rid of it, then Ill remove them and prep them again and hope it sticks.
I might go for a long drive and find some twisties to get some heat in them.
The headers have also made the car a fair bit louder too, I believe I may be the oldest ricer in NSW.
Oh, and like usual the straight swap "bolt on headers" needed to be shortened and the flange clocked for them to fit.
The car is noisy as it is, if it was just a track car I would do it but I enjoy going for long cruises, any more noise than what's going on at the moment is a non no.
The 5 is noisier than my old stripped out boat, it also has about 320 less killerwasps than he boat, I am enjoying it more than the old boat though.
Mainly because it hasn't broken yet.
Was the torque loss that bad?
I was going to do something similar in my car but if the torque loss is that bad I might mod the K&N intake I have instead.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
